08.12.2011, 19:35
Biondo Racing -RPM2 shift
Used but in excelent shape..almost new
150 euro
These double shift rpm activated switches from Sam Biondo are loaded with features, including:
* Auto reset--no buttons to press!
* Shift two gears at the same or different rpm
* Mounting tabs for easy installation
* Microprocessor-controlled timing
* Retain all numbers when powered off
* Large LCD
* Work with 4, 5, 6, 8, 10, and 12-cylinder engines
* 3,000-9,900 rpm range can be changed by pushing the buttons on the face of the unit
* Test your shifts by holding down either button for two seconds
* Two separate outputs--normally open, and closed (for CO2, air, or electric shift applications)
* Programmable repeat--can be programmed so they won't activate again at the finish line, saving air for vehicles using air, or CO2 shifters
150 euro
* Large LCD
