01.08.2010, 12:19
Can take to Drachten Finals
Clear One Windows Installation Kit
50 euro NEW
Window Installation Kit, 1/2 in. Width Rubber Gasket, Stainless Steel Hardware, Kit
Gasket is 60 durometer rubber. Hardware includes 50 stainless steel hex head flush mount bolts and nyloc nuts
![[Bild: clr-112k_w.jpg]](http://static.summitracing.com/global/images/prod/large/clr-112k_w.jpg)
4.56 ring and pinion.
Ford 9''
Pro-Gears!! with 35 spline pinion
Used but in very good shape
200 euro
Wilwood brake-pads
4 pads = 1 set for 115 euro NEW
Wilwood Disc Brakes 15A-5734K
Wilwood PolyMatrix A Compound Brake Pads
![[Bild: wil-15a-5734k_w.jpg]](http://static.summitracing.com/global/images/prod/large/wil-15a-5734k_w.jpg)
Moroso 85860 - Moroso U-Joint Girdles
25 euro NEW
U-Joint Girdles, Aluminum, Light Blue Anodized, Ford, 9 in., Set
Bolt to Bolt Length (in) 1.575 in.
Bearing Cap Outside Diameter (in) 1.125 in.
![[Bild: mor-85860_cp.jpg]](http://static.summitracing.com/global/images/prod/large/mor-85860_cp.jpg)
K&N 85-0500 - K&N Stubstack
Used but in very good shape.
somewhat modificated ivm choke-horn.
25 euro
![[Bild: knn-85-0500_w.jpg]](http://static.summitracing.com/global/images/prod/large/knn-85-0500_w.jpg)
March Performance 7211 - Crankshaft Pulley
99 euro NEW
Pulley Style Serpentine
Groove Quantity 6
Pulley Finish Clear powdercoated
Pulley Material Aluminum
BB-Chevy 6-Groove 5-3/4'' Dia. Crank Pulley, for Use with Long Water Pump/electrical pump
50 euro NEW
Ford 9''
200 euro
Wilwood brake-pads
25 euro NEW
25 euro
99 euro NEW
Groove Quantity 6
