24.06.2008, 23:19
I'm Thierry "memez" from FRANCE (alsace).
I'm pipefitter & welder
I have building chassis myself:
And after it's become this:
Of course, I want to go to the Drag Racing with BB FORD on FORD car!
In first, I want run on Super-Gas:
Engine:
- 460 bored 0.030
- Crank: Stock 2Y
- Piston : may be Probe or keit black (I'm not sure yet) with 11 comp
- APR Head Studs & Bolts
- Stock head with a little work around the valve guides and eliminated casting flash.Intake valves 2.19" , Exhaust valves 1.76"
- Cam: crane saturday night special , range 3600/7000, 246/256 @ 0.50, duration 282/292 and lift 0.563
- cam with 4 degrees advanced
- 1.7 roller rocker from crane
- intake manifold victor JR (4500)
- Holley dominator 1050 or 1150 cfm
- msd or mallory ignition, 34/36 degree timing
- headers: 48.3 mm
Transmission:
- C6 with 9 inch converter stall 4500
Rear:
9" , 4.11, spool & 35 splines
Slicks 32/16/15
Car:
-Real mustang Mach 1 1972
-2500 lbs
I hope that the drag result is 9.90 with this combo!
Thanks for any suggestions.
New photos of build:
http://memez-mach1.skyrock.com/12.html
Engine:
- 460 bored 0.030
- Crank: Stock 2Y
- headers: 48.3 mm
Transmission:
Rear:
Slicks 32/16/15
Car:
-2500 lbs
