BBC twin turbo system up to 2700hp
twin turbo setup BBC, should fit into any Jerry Bickel style chassis. Headers are for 23 degree heads, Profiler tall deck tunnel ram Intake as well
Turbos are high boost (60 psi) Holset turbos built and specced by John Sleath Racecars / UK and are brand new units. Explosion proof turbine sections, thus heavy duty units. Turbos are good for 2700+ horse power range and can handle 50 psi all day long.
-special Holset UK turbos, build to John Sleath specs and purchased through him
-custom build stainless steel headers
-twin TIAL 60mm wastegates
-100mm downpipes
-100mm aluminum discharge pipes
-twin 50mm TIAL blow offs
-Profiler tunnelram intake with airbox, twin 80mm Throttle bodies
-fuel rails for 16 injectors (EFI) with #10 inlet and #8 return
if needed, 16x 220lbs injectors (Siemens Deka) can be sold at extra cost
5800 Euro or best offer
[Bild: ci5kmeg0k4b6g3kpv.jpg]
[Bild: ci5kmrqjhwd38d603.jpg]
[Bild: ci5kn65x6tj1pk52b.jpg]
Letzter Beitrag von RST
10.02.2012, 12:54
