555 Reher Morrison + powerglide - Druckversion
+--- Forum: Marktplatz - Marketplace (
https://www.dragracing.info/forum/forum-9.html)
+--- Thema: 555 Reher Morrison + powerglide (
/thread-9318.html)
Step-a-Side - 03.10.2013
For sale:
The engine and trans from the ''INSANITY'' Chevelle.
555Cui Reher Morrison engine Super Series
Dart big M shortblock
Dart Pro 1 355 heads custom CNC'd by Reher-Morrison
around 940 hp and 14.5 to 1 compression
Erson cam 7/4 swap
Dynosheet.
1150 Dominator carb
Edelbrock Victor Intake.
Turnkey carb to pan!
Balancer/flexplate.
MSD cranktrigger set-up with cables and plugs.
Transmission Specialties Powerglide and converter;
Proline 5000
Rated to 2000hp!!
Prolite Transbrake
NASA Input Shaft
New Clutch Hub
New Servo
8 Clutch Pack
New 4340 Output Shaft
9310 1.80 Gears
New 1.80 Ring Gear
New Pins
New Thrust Washers
Deep Aluminum Pan
High Flow PG Pump
High Performance Gasket and Seals
SFI Approved Aftermarket Case
SFI Approved Aftermarket Tail Housing
"SPRAGLESS"
SUPER 8 (9") RACING CONVERTER
No Sprag to Slip or Fall. . . the Cause of Most Converter Failure
Billet Steel Turbine Hub
Anti-Ballooning Plates on the Pump and Cover
Furnace Brazed and Tig Welded Fins for Maximum Strength
1 package deal:: 13750 euro.
http://www.dragracers.nl/forum/download/file.php?id=70&mode=view/DSC_0195.JPG
