Frontrunners and more - Druckversion
+--- Thema: Frontrunners and more (/thread-8287.html)
Frontrunners and more - Step-a-Side - 05.08.2012
Can take to the Nitrolympx.
76 Super Pro ET 69 Chevelle
For sale:
Pair of Hoosier Frontrunners :25x4.5x15
New but few years old....look very good
250 euro for the pair
Waterneck Summit racing billet aluminum 16AN 100 euro
Nitrous Oxide Systems (NOS) 15913NOS - NOS Nitrous Pressure Gauge
Gauge, Nitrous Pressure, 0-1,500 psi, 1 1/2 in., Analog, Mechanical, Blue Face
50 euro
Auto Meter 4927 - Auto Meter Ultra-Lite II Analog Gauge
Gauge, Ultra-Lite II, Oil Pressure, 0-100 psi, 2 1/16 in., Analog, Electrical,
75 euro
Auto Meter 4988 - Auto Meter Ultra-Lite II Analog Gauge
used but in very good shape.
200 euro incl Hall sending unit
Speedometer, Ultra-Lite II, 0-160 mph, 3 3/8 in., Analog, Electrical,
Coan Converter
Only 3 weekend used ,,,in state of new
750 euro
top off the line Coan transmissions torque converter,
Flash stall around 5000 rpm behind a 600pk bbc
very efficient
Based on a zg/''opel core''
COA-20510
8" MAXIMUM PERFORMANCE CONVERTER W/ "SUPER SPRAG"
Recommended for naturally aspirated engines up to 900 hp
Nickel furnace brazed pump blades
Nickel furnace brazed turbine blades
Heavy gauge turbine blades for enhanced strength
Additional spot brazing at high load points
Dual anti-balloon plates
Heavy duty bearing supports
Coan exclusive 9 roller "Super Sprag"
Billet steel heat treated turbine hub
Accepts 30 spline input (TH350 / TH400)
Genuine Torrington thrust bearings
Balanced and pressure tested
Frontrunners and more - AMC Gremlin - 05.08.2012
i am interesstet on the frontrunners,can you bring it to the nitros next week ?
i am the guy with the 1972 amc gremlin,running in proet.
alex
Alex,
Will take them to Hockenheim
See you there
Tom
tom,thanx,
are you participant in hockenheim ?
in proET ?
tom,
are you shure of the size ?
as on the hoosier website i cant find that size.
alex
Alex
Yes ,thats the size.
i'm running super pro et this year.
Tom
so,they must be some years old,becouse they are discontinued from hoosier.
ok,we will see next week.
alex
