Green LUV truck boys from Bitburg - Druckversion
+---- Forum: Empfangshalle (https://www.dragracing.info/forum/forum-42.html)
+---- Thema: Green LUV truck boys from Bitburg (/thread-3683.html)
Seiten: 1 2 3
Green LUV truck boys from Bitburg - LUV Truck - 21.10.2008
Zitat:Original von Merlin
PS I'm the one with the red 41' Ford you pulled back this year in April when we had the tranny probs. Thx again and CU Thumb
Thanks for the welcome. No problem for the tow. We've been towed back a few times ourselves by other friendly racers, so we are happy to help when we can. Very nice truck BTW.
Green LUV truck boys from Bitburg - Udo - 21.10.2008
This year at Drachten they still had the blue light on , so no deep staging and curtesy staging .I don't know why and if they have it next year .
Green LUV truck boys from Bitburg - Garry - 21.10.2008
DMSB and NHRA rules should be pretty much the same, as they both ought to use FIA rules as their base ...
Green LUV truck boys from Bitburg - Ace - 21.10.2008
Welcome Alex,
You kicked my ass on the last Race Sunday at Bitburg. Bawling
Nice wheelie! Thumb I thought your Truck is called
JUNKYARD DAWG Smile
I'm the guy with the blue S 10 PU.
See you next year
Cheers
Jochen
Hello Jochen,
The truck is the JUNKYARD DAWG because it is mosly built out of parts from junk cars. Wink
The model is however a Chevrolet LUV truck. LUV = Light Utility Vehicle.
Keep working on the truck. Gettin' them to hook is fun. Camper
Hope to meet up next year.
Cheers,
Alex
Green LUV truck boys from Bitburg - TimSchmale - 21.10.2008
Hi Alex,
welcome onboard!
Am I right that you are running a BBF in your truck ?
€dit: Sorry i overlooked that 385 in your first post! 429 or 460 cui? What heads are you using right now?
Tim
Hello Tim,
No Ford motor in the Chevrolet!
It's a pump gas SBC, 350 ci stroker .040 over.
Cylinderheads are Trick Flow 23 degree
10.5:1 compression with SpeedPro Hypereutectic pistons
SCAT cast crank
Stock crankbolts
Stock rods
ARP rod bolts
Harold Brookshire solid lifter cam
Comp Cams Magnum roller rockers
Lunati valve springs
Carter 120gph mechanical fuel pump
Edelbrock Performer RPM dual plane intake
4150 750 cfm carb
Cloyes Roller timing chain
Redneck converter
Green LUV truck boys from Bitburg - ChevyV8 - 21.10.2008
Hello Alex,
You have a private message Smile.
Nice that the Luv Truck gets faster and faster.
Michael
Ok I'm sorry Spank I thought of a 385series BBF Runaway
Looks like a pretty strong running small block
Good Luck!
Tim
Green LUV truck boys from Bitburg - The lonesome Dragstripper - 21.10.2008
I Like your Truck...
[Bild: 377200240_TK2hN-M.jpg]
[Bild: 377200283_k2GCV-M.jpg]
cheers
Markus
